QPM 4.0 Unable to Monitor Policies Assigned by Map Class?
Aug 22nd, 2007
All of our MPLS links use Frame Relay tails. I would like to use QPM 4.0 to monitor the QoS policies we have assigned to these interaces. Unfortunately I can't seem to figure out how to get this to work. I believe it is having a problem with them because we are assigning the policies via a map class:
frame-relay interface-dlci 200
class qos_shape
Can anyone advise on a workaround, or potential mis-configuration?
vkapoor5 Tue, 08/28/2007 - 13:51
  • Bronze, 100 points or more
The CiscoWorks Management Center for Cisco Security Agents enables an administrator to centrally define, distribute, and monitor policies for agents. The software ships with default policies for popular Microsoft applications, such as IIS, SQL Server, and Office, as well as default desktop, server, and network policies. These default policies can be supplemented by new, user-defined policies
cesarbetancourt Tue, 10/23/2007 - 11:42
As far as i know the QPM works with interfaces and dont work with Frame Relay Map
