CCME Intl destination-pattern
Answered Question
Aug 22nd, 2007
I am trying to create a pots dial-peer that will allow users to make international calls. we are running call manager express 4.1. Does anyone have an example of a working destination-pattern that will allow any international call from theU.K I have trawled cisco web site and looked at SRND for any examples that I could adjust for U.K but without success
Correct Answer by glenn.white about 9 years 11 months ago
Hi, the last post by d.bigerstaff is a correct config and there are various other ways in which to reach the same goal (eg applying an outbound translation rule or profile to the dial-peer that just removes the leading 9) but read on if you were maybe interested in why the previous config worked...
By default, when the digits are read by the router, it will automatically strip digits that are explicitly written and then pass the extra digits that are implicitly defined.
In other words, 900 will be stripped and "T" digits will be passed. By adding the "prefix 00" to the dial-peer config means that the "00" will be added at the beginning of the implicitly defined digits.
Hope that's clear and helps your understanding.
Glenn
Correct Answer by d.bigerstaff about 9 years 11 months ago
This is our dial-peer for international calls. We're also U.K based.
dial-peer voice 7 pots
corlist outgoing call-international
description ** International **
destination-pattern 900T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/1:15
prefix 00
Overall Rating: 4.7 (3 ratings)
royalblues Wed, 08/22/2007 - 13:10
  • Green, 3000 points or more
You can create something like this
dial-peer voice 1 pots
destination-pattern 9T
port
In the CCM you can create a route pattern 9.!# and point it to the voice gateway.
Users would be required to use a prefix of 9 before dialing intl.
Narayan
silex Wed, 08/22/2007 - 14:04
I mean specifically for international calls
and also ccm express. I appreciate 9T will work but the inter digit timeout will be too long.
for a callManager In the U.K the dial pattern would be 900!
but that will not work on call manager express, I am looking for the equivalent, so that I can use it in a Dial peer
royalblues Wed, 08/22/2007 - 14:19
Well following is the configuration i have done on our CCME in UK
translation-profile incoming 1
destination-pattern 9.T
incoming called-number .
direct-inward-dial
port 1/0:15
you can ignore the translation profile as it is for incoming calls.
The interdifit timeouts could be configured under the telephony service
MS_UK_CME_R01(config)#telephony-service
MS_UK_CME_R01(config-telephony)#timeouts ?
busy Busy timeout in seconds after connect
interdigit Interdigit timeout in seconds
ringing Ringing timeout in seconds
Narayan
Correct Answer
d.bigerstaff Thu, 08/23/2007 - 00:09
port 0/0/1:15
prefix 00
Correct Answer
glenn.white Thu, 08/23/2007 - 15:38
Glenn
silex Thu, 08/23/2007 - 23:33
Thanks for your reply. For the other Dial-peers I have used the "forward-digits n" command. My understanding is that the Intl calls are variable length, so obviously forward digits command isn't relevant.
As you say, prefix with 00.
thanks for your help
