CSA5.1 upgrade
Aug 22nd, 2007
I am upgrading CSA v5.1.100 to v5.2. I have one CSAMC server and one remote CSADB server running SQL 2000 enterprise edition SP4. Is CSA v5.2 supported on SQL 2000 enterprise or will I need to upgrade SQL to 2005? Cisco's 5.2 documentation is not clear on this upgrade.
tsteger1 Wed, 08/22/2007 - 10:14
It's in there on page 3-22, you kind of have to dig:
"Microsoft SQL Server 2005 and 2000 Remote Setup
Note The following section contains overview information for setting up the Microsoft
SQL Server 2005 or Microsoft SQL Server 2000 database to work correctly with
CSA MC. More detailed SQL Server configuration information should be
obtained from your Microsoft documentation. All instructions apply to both
Microsoft SQL Server 2005 and 2000 unless otherwise specified."
