No MAC No WiFi Broadcast!
Aug 22nd, 2007
I have 5 Linksys WAP54GX Access Points. We run a large network with Cisco Catalyst 3560 PoE swithces at each location to run our IP phones. When we configure the access points to work on the switch the wireless won't boradcast (doesn't light up on the AP) and from the switch you cannot see the AP's MAC nor will it pass packets although you can see that the port is UP/UP.
Of the five AP's one works. The serial numbers are so close I doubt it's a bad batch. The one that works lights up wireless and passes packets. When plugged into a normal non-PoE switch, and also when plugged into the laptop they broadcast a perfect wireless signal. Had found somewhere on the net where it said to upgrade the AP's firmware to 1.16 (adds QoS) which didn't change anything.
We tried to get help from Linksys through live chat and the support tech. disconnected after they decided our problem wasn't easy enough for them so solve in a couple minutes. We tried changing the port on the switch as straight through, trunked(normal), and without power. Has anyone heard of this or have any ideas on how to fix this?
smalkeric Tue, 08/28/2007 - 08:42
By mentioning that the wireless doesnt show UP, you mean to say the AP powers up with Radio interface signalling down???. If so, the problem should be incompatible power between the AP and the switch. The Ap can be powered by several means.
Ensure that the switch connected to is capable of providing full power for the Ap's radio to be up.
bkbristlin Fri, 08/31/2007 - 05:59
We're powering the AP's with their own power source. We think we have figured out the problem, it appears to lie with the VLAN configuration on the switch itself. I was able to get the configuration to work just fine on a 3560 PoE straight out of the box. We have decided to go with Cisco 1240AG AP's. Gonna be a pain but good pratice for CCNA.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
