scripting and DOS batch for ACS 4.1 SE 1113
Aug 22nd, 2007
Good morning all,
Prior to switching to the appliance version of ACS, we had a couple perl scripts that would run to accomplish some accounts management.
Have any of you tried to do this since installing the appliances?
Also, is there a particular way that I can get an updated copy of the dump.txt off an appliance?
Thank you.
dpatkins Wed, 08/22/2007 - 08:24
I have been looking at this possibility. If all I wanted to do was add, move and delete users, is their a proper syntax? I mean the old, add doej is no longer valid.
I think I can work with this.
If I use a .csv file, I can run the script on a desktop and then import into the ODBC database on the ACS? Also, can I schedule when to run the ODBC updates?
