cisco netflow problem!!!
Aug 22nd, 2007
I'm trying to configure netflow on router2600 and still it's not working. here is my cisco configuration:
Current configuration : 2153 bytes
version 12.2
service timestamps debug datetime msec localtime show-timezone
service timestamps log uptime
service password-encryption
hostname GEO_OSMP
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication enable default none
username osmp secret xxx
ip subnet-zero
ip flow-cache timeout active 2
ip name-server 213.x.x.34
ip name-server 213.x.x.35
call rsvp-sync
controller E1 0/0
controller E1 0/1
interface FastEthernet0/0
no ip address
ip accounting output-packets
ip flow ingress
speed 100
full-duplex
no clns route-cache
interface FastEthernet0/0.1
bandwidth 10000000
encapsulation dot1Q 50
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip flow ingress
interface FastEthernet0/0.2
encapsulation dot1Q 60
ip address 213.x.x.39 255.255.255.240
ip nat outside
ip flow ingress
interface FastEthernet0/0.3
encapsulation dot1Q 40
ip address 213.x.x.91 255.255.255.252
ip nat outside
ip flow ingress
ip nat inside source route-map telenet interface FastEthernet0/0.3 overload
ip nat inside source route-map wanex interface FastEthernet0/0.2 overload
ip flow-export source FastEthernet0/0.1
ip flow-export version 5
ip flow-export destination 192.168.0.18 9996
ip classless
ip route 0.0.0.0 0.0.x.x.131.42.89
ip route 0.0.0.0 0.0.x.x.200.20.33 110
no ip http server
ip access-list extended interneti
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended wanex
logging history size 500
logging trap debugging
route-map wanex permit 10
match ip address interneti
match interface FastEthernet0/0.2
route-map telenet permit 10
match interface FastEthernet0/0.3
snmp-server community OSMP_LAN RO
snmp-server community osmp RO
snmp-server community kodi RW 60
snmp-server ifindex persist
snmp-server queue-length 100
snmp-server host 192.168.0.18 OSMP_LAN
control-plane
dial-peer cor custom
gateway
line con 0
line aux 0
line vty 0 4
password xxx
end
HELP MEEEE!!!!
steve.busby Thu, 08/23/2007 - 13:35
  • Silver, 250 points or more
Can you provide the output of the "show ip flow export" and "show version" commands?
