Can I use the 4 Port card on a 515E as switch ports?
Aug 22nd, 2007
I have a pix 515E with a 4 port card. Can I use these ports to connect PC directly to the PIX if I don't have a switch? then setup the same security level for each port?
Jon Marshall Wed, 08/22/2007 - 09:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I don't see why you could do this. If pix v7.x then as you say make it same security level and add command
same-security-traffic permit inter-interface
which will allow traffic to flow freely between interfaces without access-list and NAT.
Be aware though that this is not acting the same as a switch because each interface will need to be in a different vlan/subnet. This may or may not be an issue. if you need the same subnet you could look at using transparent firewall feature but i wouldn't like to say whether that will work or not without testing.
You would need to use cross-over cables to connect pc's into pix interfaces.
Jon
