08-22-2007 10:46 AM
Does anyone know if the 9020(Ver 2.1) will communicate with a device using NPIV?(HP Virtual Connect FC module.
Solved! Go to Solution.
08-22-2007 12:22 PM
NPIV is supported on a Cisco 9124e and can be ISL'd to a 9020 if you'd like. On the Cisco 9124e, the 4 or 8 fabric facing ports are E ports allowing you to ISL or Port Channel them to your 9020.
I found 2 PDF documents that explain all of this and I've attached a text file with the link's onto this reply along with page references.
Hope this helps.
08-22-2007 11:00 AM
The Core switch (in this case the 9020) needs to support NPIV to connect too into HP VC. The 9020 does not support NPIV.
08-22-2007 11:25 AM
Thanks. If a newer device(9124) were added to the storage network, could a device using NPIV be attached to it(9124) and still communicate the storage array through ISL port to the 9020s?
08-22-2007 12:22 PM
Hope this helps.
08-23-2007 06:49 AM
Thanks. I think this gives me the work around I needed.
Take Care!!!!!!!
