Aironet 1200 AP
Aug 22nd, 2007
I had to reset my Cisco Aironet 1200 AP.
Now i can't login to the web interface using the default ip
Any help?
Overall Rating: 5 (2 ratings)
andrew.brazier@... Sun, 08/26/2007 - 02:02
Was it connected to the LAN when you powered it up? If so it may have picked up a DHCP address and you should be able to find it by checking your DHCP server. Alternatively, disconnect it from the LAN and reboot it, it will try (and fail) to get a DHCP address and will revert to the address.
rob.huffman Fri, 08/31/2007 - 04:57
Hi Andrew,
I have read alot of good posts from you recently :) 5 points for the nice thinking on this one!
Take care,
