HTTP download stops at 50meg with CSC scanning
Any download off the web via HTTP from any clients, it stops at 50meg. If I setup certain IPs to bypass the CSC scanning, it goes fine. Any idea?
This is the config on CSC page:
Action on password-protected files: Deliver
Do not scan compressed file if:
Decompressed file count exceeds: 200
Size of a decompressed file exceeds: 30
Number of layers of compression exceeds: 3
Size of decompressed files is "x" times the size of compressed file: 100
Action on unscanned compressed files: Deliver
Large File Handling
Do not scan files larger than 50MB
Action on large files: Deliver
Enable deferred scanning for files larger than 2
ssoberlik Tue, 08/28/2007 - 14:00
  • Bronze, 100 points or more
In addition, because the switch executes the commands, but does not save the original file, output from the show running-config command might list the commands in a different order from which they appeared in the original file. The same is true when uploading the current configuration to a TFTP server. The configuration download stops if the total size of the CLI command file exceeds 15 KB.
