how do I add ATM command?
Aug 22nd, 2007
I need help trying to add this command to a 2811. Can someone tell me what the command is to add it to startup-config?
interface ATM1/0
description 26HCGJxxxxxx
no ip address
ip nbar protocol-discovery
no atm ilmi-keepalive
no scrambling-payload
interface ATM1/0.36 point-to-point
description DATA traffic to xxxx Street
bandwidth 1382
ip address 10.xxx.xxx.xxx 255.255.255.252
ip nbar protocol-
pvc 1/36
vbr-rt 1382 1382 1
tx-ring-limit 3
service-policy output Voice
interface ATM1/1
no ip address
shutdown
interface ATM1/2
no ip address
shutdown
interface ATM1/3
no ip address
shutdown
royalblues Wed, 08/22/2007 - 14:05
Friend,
whatever you configure goes into the running configuration.
To have the same copied to your start-up config just do
wr mem or
copy run start
you can view what is there in the start-up config by issuing the command
sh start-up config
Narayan
