Exporting the RME 3.5 inventory DB to a file w/ no human intervention-
Answered Question
Aug 22nd, 2007
Can the RME 3.5 inventory database be exported to a file w/ no human intervention? I.E not using the GUI-
The reason I ask is the Unix team has a script that exports the database to a file then does a comparison against another database dump. The difference is then imported back into RME using the crmimport command which imports devices from a file in a DIF format.
I had asked a previous question on how to export the RME DB to a file in a .csv format.
I improperly worded the question...
Correct Answer by Joe Clarke about 9 years 9 months ago
The answer is the same: no. This functionality was not built in to RME 3.x. However, I wrote a tool that is available from the old http://cosi-nms.sourceforge.net site called DevExp that facilitates this. It uses the DLMS capability of RME to export the devices and credentials to a CSV file.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 08/22/2007 - 16:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
