Voice Paging system numbers are busy?
Aug 22nd, 2007
this problem arose today and I am stumped. Our voice paging system is giving off a busy signal. i would go around check the phones to see if one is perhaps "off the hook" but there are about 350 on this site and i dont have the time. PLEASE HELP!
rob.huffman Thu, 08/23/2007 - 06:34
Hi Don,
I'm not sure how your Paging system is connected, but I'm guessing via FXS or ATA (maybe VG port). In any case, I would think that you could do a reset of the specified port and it would clear the call. Failing that you could just disconnect the line to the Paging system as well.
Hope this helps!
