VPN and IPLC
Aug 22nd, 2007
Our IPLC went down and we re-route the traffic from IPLC to VPN. After the IPLC is up. We re-route back to IPLC. Howver, we the services is ok. But we cannot ping from end-to-end. Any idea to clear the cache for VPN? Thanks
Best regards
spremkumar Wed, 08/22/2007 - 19:39
Have you connected both the IPLC and vpn on the same device ?
are you manually re routing the traffic on IPLC n VPN ?
can you post the config of the router on which the links are connected
regds
