netflow on port-channel interface not work
Aug 22nd, 2007
I have a layer 3 switch, gi1/1 & gi2/1 is port-channel and the channel port is a routed port. I have configured "ip flow ingress" for interface port-channel1, gi1/1 & gi2/1. But it seems that the netflow doesn't work. Below is the inteface config. Is there any config mistake.
int port-channel1
ip address x.x.x.x x.x.x.x
ip flow ingress
int g1/1
channel-group 1 mode on
ip flow ingress
int g2/1
ip flow ingress
Thanks.
wbreitzke Tue, 08/28/2007 - 14:09
Follwoing commands used to configure Netflow for the CatOS.
set mls flow , set mls nde 9996, set mls nde version
set mls nde enable.
avmabe Tue, 08/28/2007 - 19:25
  • Bronze, 100 points or more
what kind of cisco switch/router is this???
That makes a difference.
