boot problems on a 3600
Answered Question
Aug 23rd, 2007
hi
we have a 3600 started from flash (without memory card) and after erase startup-conf i cant take console. Can anybody help me?
thanks
Correct Answer by avmabe about 9 years 5 months ago
make sure you are using the default 9600 baud rate. You may have had it set higher before erasing the config.
Overall Rating: 5 (1 ratings)
Correct Answer
avmabe Fri, 08/24/2007 - 05:44
