Reg:2800 voice
Aug 23rd, 2007
Dear sir,
Iam having 2 2811 routers .i connected this back to back using gigabit ethernet.in that router mainrouter having Fxo pots and remote router having Fxs ports .I configured fxo and fxs ports but iam facing a small problem when i was dialing the number example 201 call is going through epbx 2 times ringing and iam getting a dialtone again i have to dial 201 then call is landing on fxs port.
so plz go through that and suggest me the solution to come out of the problem.
srinivas.D
9246571397
pranabgaya Fri, 08/24/2007 - 03:24
just check the "ring number n" configured under fxo voice-port
do this config and check .
router(config-voiceport)#ring number 1
default is "1", may be it is 2 thats why u are getting dialtone after 2 rings.
can u pls upload the voice port fxo config aswell.
