boot problems on a 3600
Answered Question
Aug 23rd, 2007
hi
we have a 3600 started from flash (without memory card) and after erase startup-conf i cant take console. Can anybody help me?
thanks
Correct Answer by avmabe about 9 years 4 months ago
make sure you have the right baud. You may have had it set higher than 9600 before the erase of the config.
Use 9600 and see if that helps.
Correct Answer by thomas.anthony about 9 years 4 months ago
what is that you get ehn you connect to console
Overall Rating: 5 (2 ratings)
Correct Answer
avmabe Fri, 08/24/2007 - 05:42
