Duplicate Address query
Aug 23rd, 2007
I'm getting lots of these error msgs. Are these genuine or could these be created by HSRP in anyway?
Aug 23 10:56:06 50523: *Mar 22 23:27:38: %HSRP-4-DUPADDR: Duplicate address on Vlan2, sourced by 0011.93d2.8c42
massimiliano.se... Thu, 08/23/2007 - 02:23
From 12.3 T System Guide: http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_system_message_guide_chapter09186a0080228540.html#wp780949
%HSRP-4-DUPADDR : Duplicate address [IP_address] on [chars], sourced by [enet]
The IP address in an HSRP message that was received on the specified interface is the same as the IP address of the router. Another router might be configured with the same IP address. The most likely cause of this condition is a network loop or a misconfigured switch that is causing the router to see its own HSRP hello messages.
Recommended Action
Check the configurations on all the HSRP routers to ensure that the interface IP addresses are unique. Make sure that no network loops exist. If port channels are configured, check that the switch is correctly configured for port channels. Enter the standby use-bia command so that the error message displays the interface MAC address of the sending router, which can be used to determine if the error message is caused by a misconfigured router or a network loop.
I hope this helps.
Best regards.
