pri isdn backup
Richard Burts Thu, 08/23/2007 - 08:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
imane
Before you posted this question in this forum you posted the same question in the WAN Routing and Switching forum and it has received a couple of responses in the WAN forum. I suggest that any further discussion of this question be consolidated in the WAN forum.
Rick
shillyar Thu, 08/23/2007 - 08:52
  • Cisco Employee,
What interface do you have you back up interface under ? as once you use the back up interface that interface will always be in standby mode.
I guess a better question is it is not dialing when the orimary interface is down ? thus not comming out of standby ?
Thx Steve
Richard Burts Thu, 08/23/2007 - 09:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Steve
The original post is pretty clear that he is doing a shutdown on the primary interface and expecting the backup to come out of standby status. It is clearly the behavior of IOS that it will NOT come out of standby if the primary is shutdown. It will only come out of standby if the primary goes protocol down (and not come out of standby for administratively down).
Rick
smothuku Thu, 08/23/2007 - 21:23
  • Silver, 250 points or more
Hi ,
Can you paste the config of the 7200 ..
satish
