SDM error notification
cardeckmann
I install a SDM in my computer, and i start the program, but not entry, because showme a error, with HTTPS in my browser, bla bla bla.
Please helpme
12 Replies 12
purohit_810
Level 5
Level 5
HTTPS:
HTTPS is supported in all images that support the Crypto/IPSec feature set, starting from Cisco IOS release 12.25(T).
Configure your router to support HTTP/HTTPS:
Router# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)# ip http server
Router(config)# ip http secure-server
Router(config)# ip http authentication local
Router(config)# ip http timeout-policy idle 600 life 86400 requests 10000
If the router supports HTTPS, the HTTPS server will be enabled. If not, the HTTP server will be enabled. HTTPS is supported in all images that support the Crypto/IPSec feature set, starting from Cisco IOS release 12.25(T).
For more requirements to run SDM, please check below link:
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_user_guide09186a0080667495.html
Dharmesh Purohit
thank you my friend
Is it useful ??
Or do u have query?
- Dharmesh
do you speak spanish my friend?
No Buddy i can't....
speak spanish.
But would tell you that.. it it was useful than rate the post okie.
Dharmesh Purohit
How i can install the SDM software in my router? i have a CISCO 1700
Above commands did you configured? that i gave you?
- Dharmesh
How can I do to download the ios for the router cisco1750?
I don't have user and password
You are :
Go on ISOHUNT.COM... Download from there LIMEWIRE software
Search into that if can get any free and it is useful......!!!!!!!!!!!!!!!!!
Dharmesh Purohit
excuse my friend, I lost the OS of myrouter 1750, and I don't know how to recover for command lines
go into HYPERTERMINAL... Upload it by XMODEM utility... my friend.
But for that you need IOS handy.
Dharmesh Purohit
I found the software for 1721, more it doesn't support for space lack in the router, I didn't find the software for 1750
