Config change records in RME
Aug 23rd, 2007
I have archive set up for nightly archiveing of config and it is successful.
Purging of records is set up to maintain 10 versions and not to purge for 26 weeks, but when I look at the version tree, I only see 1 version which is the latest version of the config.
There should be only one directory for configs, what is happeneing to the older versions?
purohit_810 Thu, 08/23/2007 - 05:19
  • Silver, 250 points or more
Select Resource Manager Essentials > Admin > ChangeAudit > Set Purge Policy.
Here i think you have set default that will be Purge change audit records older than 180 days.
See on below link, performing maintanance TASK:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_user_guide_chapter09186a008035771b.html
Dharmesh Purohit
David Stanford Thu, 08/23/2007 - 06:08
  • Cisco Employee,
How often has the config changed on the device? Is it archiving new configs very often?
wilson_1234_2 Thu, 08/23/2007 - 06:44
It is archiving every night.
Some devices the configs to not change often.
Some have changed quite a bit.
Joe Clarke Thu, 08/23/2007 - 07:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
A config will not be archived unless an interesting change has occurred. Interesting changes are dictate by those that do not match the exclude commands configured under RME > Admin > Config Mgmt > Exclude Commands.
So, while config archive may be attempted every night, only changed configs will be written to disk, and only they will show up in the version tree.
wilson_1234_2 Thu, 08/23/2007 - 10:40
Thanks for the reply.
I remmember you mentioning that before, but the configs have changed.
That is the thing, on some devices there should be numerous versions and I am only seeing the one.
Joe Clarke Thu, 08/23/2007 - 10:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should pick one device which does not have its latest config in the archive, and troubleshoot that. Enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Loglevel Settings, run a Sync Archive job on that device, then look at the dcmaservice.log for any obvious errors.
