PRI and Dialogic
Answered Question
Aug 23rd, 2007
I have anewly created, internal pri. In the other end, we have a server that will call a parent when a child is absent from school. That part works fine. But there is also a feature we'd like to use that allows the parent to call in to check message, so this box needs to answer a call. What would make a specefic number ring on this box? I'm sure you'll need more info to answer this, so if you'd like to try, let me know and I'll post whatever info (configs, etc) that may help.
Correct Answer by jason-calbert_2 about 9 years 6 months ago
This should be simple enough if I understand the problem correctlly. lets say that the number you decide upon is 1000. Create a routerpattern of 1000 and then under gateway/routelist choose the PRI that you connected to the box. The box on the other side will have to have some sort of mechanism to answer the call. If you want to give me more info we can see if we can get it to work. I have a fax server that we are using possible in the same way.
Jason
Overall Rating: 5 (1 ratings)
Correct Answer
jason-calbert_2 Mon, 08/27/2007 - 12:34
Jason
charliez Tue, 08/28/2007 - 11:51
I got it. I had missed something in my route pattern. Thanks.
