Deleting ACL removes access-group 101
Aug 23rd, 2007
Hey all. I was trying to delete a recently added line to acl 101. I copied acl 101 to notepad, removed the line..Did a no access-list 101 on the PIX 515, then copied in my corrected acl into the PIX.
After an hour of searching, I found that removing the acl 101 actually caused the "access-group 101" line further down in the configuration to disappear.
Can someone explain this to me? What is the best way to delete just one line from an ACL?
purohit_810 Thu, 08/23/2007 - 05:43
  • Silver, 250 points or more
Run command: sh access-list | i {IP address}
You will see related access-list with line:
access-list 102 line 14 extended permit udp any any eq www
Or
access-list 102 line 4 extended deny tcp any host XX.XX.XX.XX eq www
Put NO command
No access-list 102 line 4 extended deny tcp any host XX.XX.XX.XX eq www
It will be delete only one partucular Access-list.
Don't fear.
Dharmesh
