871w: setting up port forwading for a web server
Aug 23rd, 2007
We need to set up port forwarding for a web server we are running and doing some testing on. I will need to open up ports 80 and 8080. I'm not sure how to go about this, whether I would set up a new route, or is if the router has some other functionality for this. Thanks in advance.
spremkumar Mon, 08/27/2007 - 01:44
Need more info on your current setup,connectivity details,ip addressing scheme and a small piece of network diagram representing your network.
regds
Pra3tor1an Mon, 08/27/2007 - 05:04
adding port forwarding to 80 and 8080 worked in this case:
ip nat inside source static tcp 192.168.69.10 80 80
ip nat inside source static tcp 192.168.69.10 8080 8080
thanks
