huljoscttu Thu, 08/23/2007 - 11:41
It depends on which specification of wic you are using. Search "wic" in the cisco search box, and it will give you different listings to look at.
ilnaiduccna Fri, 08/24/2007 - 08:17
hello,
Any where the max e1 bandwidth / speed is 218 kbps is it right or not?
naidu
mohammedmahmoud Fri, 08/24/2007 - 08:28
  • Green, 3000 points or more
Hi Carl,
The maximum speed on an E1 WIC is 2M.
HTH,
Mohammed Mahmoud.
