ASA 5505 PPPoE Config???
Aug 23rd, 2007
I'm trying to walk a someone through changing the PPPoE authentication password on an ASA 5505. I dont have it in front of me soI dont remember were to navigate on the ASDM GUI. Where do we need to go to make that change?
msdesai Thu, 08/23/2007 - 07:15
Go to the Configuration > Interfaces pane
Select the Interface and Click on Edit:
To obtain an IP address using PPPoE, check Use PPPoE.
a. In the Group Name field, specify a group name.
b. In the PPPoE Username field, specify the username provided by your ISP.
c. In the PPPoE Password field, specify the password provided by your ISP.
d. In the Confirm Password field, retype the password.
e. For PPP authentication, click either PAP, CHAP, or MSCHAP.
Please refer to below link
http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/user/guide/ifcs.html
Also I have attached the Screenshot from ASDM
MD
anitakuang Tue, 10/09/2007 - 17:28
Hi Msdesai,
Does it support PPPOA at all?
Cheers
Anita
