Multiple VPNs to non related sites
Aug 23rd, 2007
I have a 2851 router with an established shared-key vpn to a remote site. I would like to add a new shared-key vpn to an unrelated site. Can I make an additional isakmp policy, transform set etc? Also should I change the crypto map or just renumber it? Any help with these issues would be great. Thanks (As you can tell I am new to the setup of vpns)
Jon Marshall Thu, 08/23/2007 - 10:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes you can have another isakmp policy if you want with a different index number although you can use the same one you have if the parameters are the same.
Yes you can create another transform-set although again you can use the existing one if it matches your needs.
You can only appply one crypto map to an interface so you use the same crypto map name with a different index number.
Jon
