Changing management vlan on 2940 switch
Aug 23rd, 2007
I am in the process of removing the IP address's from VLAN 1 and configuring a new IP address on VLN 2 as part of a security initiative.
The network consists of a 6513 at the core and a bunch of 3560's and 2940's direclty connectd to the core switch.
All went fine on the 6513 and the 3560's, unable to reach the 2940's once the change is made.
I can only reach the 2940's from the core switch.
Any ideas.
Overall Rating: 4 (1 ratings)
Joe Clarke Thu, 08/23/2007 - 08:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Check the ip default-gateway command, and make sure it's correct.
salatfuji Thu, 08/23/2007 - 09:31
Thanks, for the hint.
I was trying to do this remotely via script, and the problem is that as I make one of the two changes ( gateway or IP address ) I loose connection to the switch.
I'm going to test copying a new startup-config and then reload the switch.
Thanks.
