ACS Upgrade - Remote Agent question
Aug 23rd, 2007
we want to upgrade ACS Solution Engine from 4.0 build 23 via 4.1 to 4.1.3.
We also use Windows Remote Agent to authenticate External User Database (Windows Domain Users).
Does anybody know the best way to upgrade.
Should we upgrade Windows Remote Agent before ACS Upgrade to minimize the Downtime ???
Is Remote Agent from ACS 4.0 compatibel with ACS 4.1 ???
Any experiences ?
Thank you for helping !!
Overall Rating: 3.5 (2 ratings)
Jagdeep Gambhir Thu, 08/23/2007 - 08:50
ACS and RA has to be on same code, if you want to use AD.
I would suggest you to upgrade appliance first and then remote agent. Remote agent takes not more then 2/3 mins to install.
Ex db auth will fail till ACS and RA are on same code.
It is better to upgrade during off production hrs.
Upgrade path,
4.0 build 23---> 4.1----> 4.1.3
at Thu, 08/23/2007 - 09:01
Thank you for your answer.
for some reasons we must use Windows Domain Authentication.
So we need to install Remote Agent after each upgrade, that means
4.0build23--->4.1 and Upgrade Remote Agent ---> 4.1.3 and Upgrade Remote Agent
4.0build23---->4.1---->4.1.3 and Upgrade Remote Agent ?
Jagdeep Gambhir Thu, 08/23/2007 - 09:06
You can do that either way. If you want AD authentication during upgrade then,
Step 1
acs 4.0
RA 4.0
Step 2
ACS 4.1
RA 4.1
Step 3
ACS 4.1.3
RA 4.1.3
