IDS 5.1(6)E1 Meta Engine Signatures
Answered Question
Aug 23rd, 2007
Is there any documentation that shows ALL signatures associated with a meta signature? Thanks
Correct Answer by attmidsteam about 9 years 8 months ago
The only definitive method is to look at the components of a signature when tuning it (via VMS for example).
Overall Rating: 5 (1 ratings)
Correct Answer
attmidsteam Thu, 08/23/2007 - 10:07
  • Silver, 250 points or more
hendetl Thu, 08/23/2007 - 11:14
That's what I was trying to avoid but was afraid it was the only way. Oh well, thank you very much for the response. Greatly appreciated.
mhellman Thu, 08/23/2007 - 13:15
  • Blue, 1500 points or more
I'm not sure exactly what your after, but maybe this will help?
Nearly all signatures that are components of a meta signature do not have anything set in the action field. In the IDM, you can sort by the action column and you can copy/paste into Excel and massage as needed.
btw, I'm on V6..but as I recall you can do the same or similar with V5.
