update old asdm image on fwsm blade
Aug 23rd, 2007
There are two catalyst 6500 with fwsm with active/active failover. One of them has old version of asdm image. The admin context is active on the first fwsm blade (this with correct asdm image) so I can?t make any copy tftp command from the second fwsm blade to update asdm image. The image is so old that I can?t update it from web browser or asdm launcher. Do you know any trick to update image on the second fwsm blade
tomasz.ostaszewski Thu, 08/23/2007 - 14:31
You can upgrade image of asdm (copy tftp ...)only using system context but when admin context of this blade is in standby mode (because of failover) there is no network connectivity at the system context.
