MS IAS RADIUS for WLC management authentication
Aug 23rd, 2007
Is it possible to use Microsoft IAS RADIUS server to authenticate to the web-based management interface of Wireless LAN Controller 4402? Is there a document available for that?
Overall Rating: 5 (1 ratings)
momeara Mon, 12/20/2010 - 08:47
Has anyone gotten authentication for the HTTPS login to the management interface working through MS IAS?  I would rather use LDAP if someone knows how to do that, but in the WLC management interface, the only options for Security/Priority Order/Management User are TACACS, RADIUS, and Local.  Using RADIUS to authenticate the login to the management interface, would any attributes need to be set, because they appear to be for WLAN users;
WLAN-ID, QOS Level, DSCP Setting, 802.1p Tag, Interface Name, and ACL Name.  The document I'm using doesn't give a lot of guidance;
Nicolas Darchis Mon, 12/20/2010 - 11:48
you're looking too far away I think. Attributes are needed only if your user is a LobbyAdmin as far as I remember. Attributes are needed if you use tacacs though but I don't remember any for radius.
Just configure IAS to authenticate users and the WLC to have the IAS as radius server for management users. It should do the trick.
Trending Topics - Security & Network
