Joe Clarke Wed, 08/29/2007 - 12:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Doesn't seem right to me. What version of IOS is the 3800 running? Do the interfaces show up correctly when viewing the device inventory under QPM > Devices > Device Information > Interfaces? If the interface doesn't show up here, and there is no error associated with the device, there may be an SNMP issue collecting inventory for it. Try rediscovering it.
Of course, when defining your constraint, make sure you select the 3800_ISR type. If all else fails, you should be able to define the constraint manually.
