08-23-2007 07:00 PM - edited 03-03-2019 06:27 PM
A question here. I have configured a policy map, although the packet value does get incremented at the class-map but the traffic that is policed is not being conformed. Any ideas?
policy-map test
class test
police cir 256000
conform-action set-mpls-exp-imposition-transmit 1
exceed-action drop
show policy-map int Se1/0 in
Class-map: test (match-any)
20037508 packets, 1027071174 bytes
30 second offered rate 22000 bps, drop rate 0 bps
Match: ip precedence 1
30 second rate 22000 bps
police:
cir 256000 bps, bc 8000 bytes
conformed 0 packets, 0 bytes; actions:
exceeded 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps
08-23-2007 07:14 PM
The match has 'ip precedence 1', are you marking the traffic as such ?
By default, packets have 'ip precedence 0'
08-23-2007 07:21 PM
Yesh, I am marking it as 1 at the remote CE.
But if u take a look, there are packet at the ingress policy map, just that at the policing side, it is not confirming to any packets
police:
08-23-2007 07:53 PM
If you use any other type of conform action, does the value increments ?
Can we see a 'show ver' from the router ?
08-23-2007 08:32 PM
The set-mpls-exp-imposition-transmit action of the police command is only supported on the PE input interface that is connected to the CE.
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/swconfig/cfggdes/qoscf/10qmpls.htm
Sundar
08-23-2007 11:53 PM
The value does not increment.
The IOS on the router is 12.3(5d). Is there any IOS bug issue for this version with regards to this issue?
