Ether Channel
Aug 23rd, 2007
Can an yone tell do we configure Ether channel between 2 switch ports. IS it also possible to configure Channeling between a Switch and Server . What is advanatage of LACP over PAGP.
Akber.
Overall Rating: 5 (1 ratings)
massimiliano.se... Thu, 08/23/2007 - 23:03
There are some configuration examples at: http://www.cisco.com/en/US/tech/tk389/tk213/tech_configuration_examples_list.html
It is possible configure an etherchannel between a server and a switch; you can view http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a008089a821.shtml.
LACP is standard based on IEEE 802.3ad; PAgP is Cisco proprietary, therefore PAgP cant'be used between Cisco switches e non-Cisco switches.
I hope this helps.
Massimiliano.
