MARS Update Problem: 4.2.4 --> 4.2.5
Aug 23rd, 2007
Dear all,
I try to update a CS-MARS 100 from 4.2.4 to 4.2.5. For more than 18 hours the update procedure hangs on the step "updating database schema".
[pnadmin]$ version
4.2.4 (2428)
[pnadmin]$ pnadmin http://192.168.101.129/mars/csmars-4.2.5.2456.pkg [] []
Unknown comand "pnadmin http://192.168.101.129/mars/csmars-4.2.5.2456.pkg [] []"
[pnadmin]$ pnupgrade http://192.168.101.129/mars/csmars-4.2.5.2456.pkg [] []
Downloading ...
######################################################################## 100.0%
Upgrading ... - Stopping CS-MARS applications : #
- Updating database schema : #
The MARS is reachable via TCP/IP. But nothing is going on.
Any idea whats going wrong?
secaron Sun, 08/26/2007 - 23:58
ok, after no progress within 12h I rebooted the system. Then I restarted the upgrade-procedure and everything worked well.
