Call centre
Answered Question
Aug 23rd, 2007
I am a newbie to Call centre solutions, Can some one show me where i can start? What must i know? It would be helpful to receive guides too, Thank you in advance..
Overall Rating: 5 (1 ratings)
jerryeguru Fri, 08/24/2007 - 00:31
hello Juan, i have found the reply so helpful, thank you, we are going with the Cisco Unified Contact Center solution.
One more thing, any configuration guides i can find?
lpezj Fri, 08/24/2007 - 00:39
  • Gold, 750 points or more
For Enterprise, you can get all the information at:
http://www.cisco.com/en/US/products/sw/custcosw/ps1844/tsd_products_support_general_information.html
For Express, you can get the information at:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/tsd_products_support_general_information.html
It is a lot information, but it will help you.
Hope this helps,
Juan Luis
Zin.Karzazi Fri, 08/24/2007 - 04:32
  • Silver, 250 points or more
You should care about the number of Skillgroup if you have a distrubited deployment: your ICM controller and your PGs dont reside on the same site. Cisco porvide you then with a calculator (ACD/CallManager Peripheral Gateway to ICM Central Controller Bandwidth Calculator ) which tell you how much Bandwith you need between G and Controller (one of the parameter that you specify on the calculator is the number of Skillgroup)
check the Calc on this link:
http://tools.cisco.com/s2slv2/viewProcessFlow.do?method=browseStepsPage&modulename=browse&stepKeyId=55|EXT-AS-107287|EXT-AS-107288|EXT-AS-107301&isPreview=null&prevTechID=null&techName=IP%20Communications&sessionTimeStamp=#
