ATM ces svc nf signal detection
Aug 24th, 2007
Dear forum,
I have atm network with ATM and CBR interfaces for transfer nf audio signals like phones. My question
is how can I from console detect if is nf audio in
for example ces svc 15?
Thank you verry much for any solution.
Best regards,
Martin
Anonymous (not verified) Thu, 08/30/2007 - 09:31
when the optional CAS and on-hook detection features are enabled, the following conditions apply:
The permanent virtual connection (PVC) provisioned for the CES circuit always exists.
The bandwidth for the CES circuit is always reserved.
During an on-hook state, most of the bandwidth reserved for the CES circuit is not in use. (Dummy cells are sent from the ingress node to the egress node to maintain the connection.) Therefore, this bandwidth becomes available for use by other network traffic, such as available bit rate (ABR) traffic.
During an off-hook state, all the bandwidth reserved for the CES circuit is dedicated to that circuit
