VPN Configuration
Aug 24th, 2007
We have a VPN Concentrator 3005. We want use this VPN Concentrator in a test environment. We want to copy the configuration from the production VPN Concentrator to this test VPN Concentrator (we will change the Public and Private IP addresses). Is there a way to do this without going to each screen to configure it manually? Thanks.
Diane
irisrios Thu, 08/30/2007 - 09:35
  • Silver, 250 points or more
For copying the config from one vpn concentrator to another you may setup a PC or laptop for TFTP. First make the vpn concentrator from which the config is to be downloaded as vpn server using command "tftp enable" on concentrator and the PC/laptop as tftp client. After this make the PC/laptop as TFTP server and the vpn concentrator on which the config is to be downloaded as TFTP client using command "tftp get config". Following link may help you http://www.cisco.com/en/US/docs/security/vpn5000/sw/sw52/configuration/guide/SWInst.html#wp1009784
