mchandak Fri, 08/24/2007 - 10:45
  • Gold, 750 points or more
I'm not sure as to what information you are trying to export and then import it to CM 4.3. Also, is there a reason why you dont want to do a upgrade from CM 4.1(3) to 4.3(1) as this is a tested and supported upgrade option. The same is mentioned at http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/prod_software_versions_comparison.html
Please check the upgrade document available at
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_3/install/upgrade/upg431/index.htm
Please before you start the upgrade please ensure that you run Upgrade Assistant before starting the Upgrade to confirm the system is ready for upgrade.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_1/install/upgrade/up431tl.htm
Hope this helps.
