Cat. 4510 Unexpected Reload
Aug 24th, 2007
Our 4510 switch appears to have reloaded randomly twice in the past two weeks. It has caused a major disruption. When I look at a "sho ver" the output displays "last reset from reload".
My question is does this mean someone had to issue a reload command from terminal or console for this to happen or could this be a bug or other issue that is just reading reload as the cause?
Thanks. Will Rate Post.
Overall Rating: 4 (1 ratings)
avmabe Fri, 08/24/2007 - 09:05
  • Bronze, 100 points or more
I would set the box up to syslog to see if someone is issuing the reload command. Also get a good handle on how many people have access to this box and if they have individual logins. Setup syslog and snmp traps to be collected.
But as for the reason, I recall seeing a box crash and said it was from reload, even though no one rebooted it. I'll have to look around more but I'm pretty sure you can see that in show ver and it not be a manual issue of "reload".
It couldn't hurt to also run your version of code through on CCO to see if there is a specific but you are running into. I'd also open a TAC case and if you are running older code, upgrade it.
