Two T1 lines
Aug 24th, 2007
We have a Cisco 2800nm router installed with 2 T1's attached to 2 wic1 CSU/DSU card. We are trying to add 2 VWIC-2MFT-T1-DI= card. We installed last night, and tried to move 1 of the T1s to 0/2/1:0, but it never connected. We got line up, but protocol down.
Status seems to indicate that PPP never establishes the link.
Can you check the configuration and offer any suggestions?
Serial0/2/1:0 is up, line protocol is down
Hardware is GT96K Serial
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 245/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Listen, multilink Closed, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Last input never, output 00:00:28, output hang never
Last clearing of "show interface" counters 00:02:40
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
10 input errors, 10 CRC, 9 frame, 9 overrun, 0 ignored, 5 abort
10 packets output, 390 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
1 carrier transitions
Timeslot(s) Used:24, SCC: 1, Transmitter delay is 0 flags
site#sh run
Building configuration...
Current configuration : 4552 bytes
version 12.4
service password-encryption
hostname site
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
resource policy
memory-size iomem 25
clock timezone EST -5
clock summer-time EDT recurring
no network-clock-participate wic 2
no network-clock-participate wic 3
ip subnet-zero
ip cef
controller T1 0/2/0
framing esf
linecode b8zs
channel-group 0 timeslots 24
controller T1 0/2/1
framing esf
linecode b8zs
cablelength short 133
controller T1 0/3/0
framing esf
linecode b8zs
controller T1 0/3/1
framing esf
linecode b8zs
interface Loopback0
description **** IP Address of Multilink Serial Lines ****
ip address 162.81.11.210 255.255.255.252
interface FastEthernet0/0
no ip address
duplex auto
speed auto
no mop enabled
no mop enabled
interface Serial0/0/0
description **** To Sprint HCGS/987682//LB ****
no ip address
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
interface Serial0/1/0
description **** To Sprint HCGS/987683//LB ****
no ip address
ip verify unicast reverse-path
no ip redirects
no ip unreachables
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
interface Serial0/2/0:0
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
interface Serial0/2/1:0
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
no fair-queue
pulse-time 1
ppp multilink
interface Virtual-Template1
ip unnumbered Loopback0
ppp multilink
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password
login local
scheduler allocate 20000 1000
end
test#
azmath.hk Fri, 08/24/2007 - 09:15
What to you mean by edit?
Guys, Any suggesstion?
azmath.hk Fri, 08/24/2007 - 09:19
Please help me with the configuration. I have to finsih this task ASAP
Richard Burts Fri, 08/24/2007 - 09:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Azmath
I wonder if the issue is in the timeslots that are configured. It is my understanding that the timeslots are configured as a list and if you give a single number then I believe that a single channel is allocated. I am assuming that you want a full T1 not a single channel. I suggest that you give this a try:
controller T1 0/2/1
channel-group 0 timeslots 1-24
Rick
avmabe Fri, 08/24/2007 - 09:50
  • Bronze, 100 points or more
I would recommend opening up a TAC case.
avmabe Fri, 08/24/2007 - 09:51
also put in a loopback plug and see if you can get it up locally without the telco.
mohammedmahmoud Fri, 08/24/2007 - 09:50
  • Green, 3000 points or more
As Rick has stated, you should configure appropriate T.S via "channel-group 0 timeslots x-y", and this configuration must match with your provider.
HTH,
Mohammed Mahmoud.
Edison Ortiz Fri, 08/24/2007 - 10:12
  • Hall of Fame,
    Founding Member
Did you verify with your provider that they are using PPP as the encapsulation protocol ? Both ends of the link must match, try removing encapsulation PPP and see if the lines goes up/up.
robwagner Mon, 09/24/2007 - 14:06
I ran into this same thing over the weekend. Did you find a solution?
Richard Burts Tue, 09/25/2007 - 02:43
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
Would you post the router config and the output of show interface?
Rick
robwagner Tue, 09/25/2007 - 07:31
I?m replacing a 2621 with VWIC-2MFT-T1 cards and going to a 2821 with VWIC2-2MFT-T1/E1 cards.
When I do the cut-over all of my serial interfaces are showing up, line protocol is down.
All of my existing routers have the older vwic-2mft-t1 cards. My new configuration is a copy of my old 2621 config, so I don?t see where the problem lies.
I?d like to try swapping out the router again this weekend, but I?m not sure what is causing the protocol to be down. Any ideas?
controller T1 0/0/0
framing esf
linecode b8zs
controller T1 0/0/1
framing esf
clock source internal
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
interface Serial0/0/0:0
description Serial Interface to Berkeley
ip address 10.35.2.1 255.255.255.252
ip access-group 101 in
ip pim sparse-dense-mode
encapsulation ppp
ip route-cache flow
ip summary-address eigrp 100 10.0.0.0 255.0.0.0 5
ip summary-address eigrp 100 1.0.0.0 255.0.0.0 5
ip mroute-cache
fair-queue
interface Serial0/0/1:0
no ip address
interface Serial0/1/0:0
description Serial Interface to Glendale
ip address 10.35.3.1 255.255.255.252
ip directed-broadcast
encapsulation ppp
ip route-cache flow
ip mroute-cache
ppp authentication chap
interface Serial0/1/1:0
description Serial Interface to Cypress
ip address 10.35.4.1 255.255.255.252
encapsulation ppp
ip route-cache flow
ip mroute-cache
fair-queue
Richard Burts Tue, 09/25/2007 - 07:48
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
Since the new card supports both T1 and E1 there needs to be a configuration command to tell the router which one it is. The configuration that you posted does not have any "card type t1" commands and I am not sure whether that is because there is not any of this command in your config or whether you just did not think to include it. If it is not there then add it. If it is there then we need to look further for an explanation.
Rick
robwagner Tue, 09/25/2007 - 08:22
I have these two lines, that I forgot to include in my config above:
card type t1 0 0
card type t1 0 1
pciaccio Tue, 09/25/2007 - 02:51
  • Silver, 250 points or more
After reading the history and seeing your posting, The only thing that is obvious that should be looked at is the LBO. You have it set for short. How far is your router from the telco handoff point in your telco room or demarcation point in your building? If it is long (approx > 150ft) then you should increase the LBO of your line. You may want to view or post the show controller T-1 status of this line to see if you are receiving any T-1 errors. Good Luck...
JORGE RODRIGUEZ Tue, 09/25/2007 - 08:37
Hi, this is a very interesting thred and would like to learn the resolution outcome, in reading the respnnces from all it seems this issue is more of a configuration specially using the seccond generation T1/E1 cards, I would like to suggest to be prepare with debug commands in preparation for your second cutover attempt.
Referecen this doc for troubleshooting or print it prior to cuting over and plan troubleshooting strategy with debug commands in the event you have issues again, I personally hate to rollover implementations but second attemtps is best to be prepared.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml
Jorge
robwagner Tue, 09/25/2007 - 09:24
I checked the controllers and they are already set to long. I can't post the controller T-1 status until this weekend after I try the cutover again.
robwagner Thu, 09/27/2007 - 08:01
I figured out my line protocol down problem...
I made lab environment with an old 2621, the older version T1 interface card and made a T1 x-connect cable; I connected this to the new 2821 router and I had the same results: the ser int was up, but the protocol was down. My problem was the command "ppp authentication chap". The routers were looking for the username of the connecting router and a matching password. I renamed my new router to HQ_2821 instead of HQ_2621 and didn't have the username line correct. Once I added the new username and matching password the routers were able to authenticate.
So there is not a compatibility problem with the old vwic cards and the gen 2 vwic cards.
Richard Burts Thu, 09/27/2007 - 08:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
Thanks for posting back and telling us that the problem was solved and how you solved it. It makes the forum more useful when people can read about a problem and can read about the solution to the problem.
It is good to have confirmation that the problem was not a compatibility issue between types or generations of WIC cards.
Rick
