How many access points does a WLC 2006 support?
Answered Question
Aug 24th, 2007
I'm under the impression that each 2006 controller can only support up to 6 access points. Can someone confirm this for me? I'm unable to find documentation on this device through cisco as the 2000 controllers are EoS/EoL now..
Reason I ask is, the only documents I found that relate to that were the WLC 4.1 controller config guides, and they say the max supported for 2000 controllers is 6... yet I have one running now that has 7 associated with it. All 7 are valid APs.
It's confusing, so I would like a bit of clarification with what's going on.
Thanks in advance.
Correct Answer by jakew about 9 years 4 months ago
Wired APs count as 1 AP, non-RAP mesh APs count as 0.5. The 2006 supports 6 APs, but 12 APs will be allowed to join to support failover/redundancy.
Overall Rating: 4.7 (3 ratings)
jpeterson6 Fri, 08/24/2007 - 10:20
Thanks, it's as I thought..
.. any idea why a 7th is able to register though? We originally had two controllers managing 7 AP's but one of the controllers is having trouble, so all 7 are associating with the first one.
If it helps, all 7 AP's are mesh 1510's, two of them are Root APs.
retiredmarine Sun, 08/26/2007 - 05:48
i believe the mesh ap's only count as a 1/2 ap and root counts as a whole. I just can't find a reference.
rob.huffman Sun, 08/26/2007 - 09:03
Hi Jeff,
My understanding of this is that only "wired" AP's are counted against the over-all total.Thus you have not exceeded the maximum number of 6 supported AP's.
Hope this helps and things are good in Winnepeg!
Rob
Correct Answer
jakew Sun, 08/26/2007 - 09:36
rob.huffman Mon, 08/27/2007 - 09:03
Hi Jake,
Thanks for clearing up this question for everyone :) 5 points for your good work here!
Take care,
Rob
jpeterson6 Wed, 08/29/2007 - 08:32
Thanks.
I wish that kind of stuff was better documented (If it is, I certainly didn't see it anywhere!).
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
