hyperterminal problems
Answered Question
Aug 24th, 2007
I inherited a 2950t-24 switch. I attempted enter privileged exec mode, but was unable to guess the secret password. I initiated the password recovery but after i broke the restart the switch stopped echoing my responses to hyperterminal. I enabled echo so that i can see what i am typing, but i still can not execute commands. I restarted the switch a few times, as well as my pc; no change. I checked the com1 settings (9600 , 8, none, 1, none) no change. any help would be great.
Correct Answer by srue about 9 years 10 months ago
don't use hyperterminal. download a trial version of securecrt. just my 2cents.
Overall Rating: 5 (1 ratings)
Correct Answer
srue Fri, 08/24/2007 - 10:28
  • Blue, 1500 points or more
alexsolliday Fri, 08/24/2007 - 10:37
thanks, i tried putty and got the same results. do you think that i should try securecrt too?
alexsolliday Fri, 08/24/2007 - 12:09
i tried using secureCRT and it works now. however I can't reset the password as the Flash directory is unavailable.
unable to stat flash/: permission denied
any thoughts?
jasonrandolph Fri, 08/24/2007 - 12:38
Hyperterminal will occasionally flake out and not recognize keyboard input to serial devices.
omar_g2005 Mon, 09/24/2007 - 14:43
How do we diable hyperterminal to use CMD instead of hyperterminal in CNA?
glen.grant Mon, 09/24/2007 - 17:35
  • Purple, 4500 points or more
Use Tera Term SSH , freeware that works!!!
