Campus Manager - SwitchCloud Confusion
Aug 24th, 2007
How are the Switch-Clouds (Topology Services --> Network Views --> LAN Edge View --) formed ?
We have around 20 Sites, which are connected to the central site through MPLS network. There is no L2 connectivity between the sites. Each site has a different IP Addressing Scheme and VTP Domain.
All sites have their own Switch Clouds except for 2 sites, which are bundled in One Switch Cloud. What could be the reason for that ?
Naman
Joe Clarke Fri, 08/24/2007 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Switch clouds are formed by interconnected switches separate by routers (the router boundary forms the outline of the cloud). So, if two sites are showing in one cloud, there must be a switch connecting them.
mnlatif Fri, 08/24/2007 - 09:55
As far as I know, there is No L2 connectivity but I will check again.
Naman
Joe Clarke Fri, 08/24/2007 - 10:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
May not have to be L2 connectivity. Check the devices that interconnect to the two site. What are they?
mnlatif Fri, 08/24/2007 - 15:09
I re-init the DB and ran Data Collection again. The problem went away and all is clean\ok now..!
Don't know what could have happened ?
The two sites are not directly connected but connected to a central site through Frame\MPLS network.
Thanks \\ Naman
Joe Clarke Fri, 08/24/2007 - 15:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yeah, if there are no CDP neighbor relationships between the two sites, it would be very hard to put them in the same switch cloud. Perhaps there was some relationship at one point that no longer exists.
