RICS0001:Internal Error,unable to process the collected data from the devic
Aug 24th, 2007
Running Ciscoworks LMS 2.6 on a Win2003 box. Recently. I've noticed an increase in the number of device on periodic inventory collections with this error message:
RICS0001:Internal Error,unable to process the collected data from the device.
Is there a way to fix a record that has this problem without deleting it and then having to re-discover?
Joe Clarke Fri, 08/24/2007 - 13:53
There is a bug that has a patch that may fix this problem. However, you need to provide the IC_Server.log to see if you are hitting this bug.
bm_5789 Sat, 08/25/2007 - 06:27
I've encountered the same problem. Contacted TAC and was sent a patch. It worked on the particular device that the error showed up in the inventory. However, more devices have the same error now so the patch was not effective in solving the error comletely.
