Sup 720 status LED
Aug 25th, 2007
Hi friends,
There was a power down in the data center and after it was up, the status LED on the 720 sup showed the following:
1. On the first 6513 switch, Port 2 UTP link led showed amber for both active and standby supervisors.Nothing was connected to those ports.
2. On the second 6513 switch, Port
Port 1 and Port 2 link LED's showed amber for both active and standby supervisors. Nothing was connected to those ports.
Right now, everything is normal, but do these ambers indicate any problem.
Thanks a lot
Gautam
