CSM-SSL URL Redirect case
Aug 25th, 2007
we have CSM-SSL Module installed in our core 6509 switch, we use it to provide SSL and load Balance for our website
also we use it to rewrite all http traffic to be https secure traffic.
so anyone type www.abc.com in his browser it will redirect him to https://www.abc.com/ejoin/index.jsp and also CSM load balance between 3 servers
we develope a new system and it can be used in mobile phones so we registered a new domain called
www.abcmobile.com with the same public IP registerd for www.abc.com but it will worked in 2 different servers.
what we want to do is when anyone access from his mobile to www.abcmobile.com the CSM-SSL module redirect
him to https://www.abc.com/mobile/index.jsp
so is this possible to be done in the CSM Module
Talal Habeeb
j-block Thu, 08/30/2007 - 13:44
I noticed in the Cisco documentation, the URL rewrite will only rewrite HTTP redirects in the location HTTP header field and will not rewrite embedded HTTP references.
Note The URL rewrite feature supports the rewriting of redirection links. The system scans only the "Location:" HTTP header field in the response from the server and rewrites the rules accordingly. The URL rewrite feature does not support embedded links.
habeeb_talal Fri, 08/31/2007 - 23:50
Thanks j-block for your reply, is there any forum for CSM Module?
sgonsalv Sun, 09/02/2007 - 17:33
Yes, there is the "Application Networking" forum which deals with all things content networking, CSMs etc
Cheers
Sheldon
