Problem, VPN connection over wireless
Aug 25th, 2007
Not able to access anything on private network when using wireless connection. If connected to same router with cable it allows access. When connecting via wireless the VPN connection is established but access to internet, email server, network folders fail. Looking for ideas on how to correct this.
tstanik Thu, 08/30/2007 - 13:46
  • Bronze, 100 points or more
In order to verify this configuration, configure the SSID vpnclient in the wireless client with the same security parameters configured in the WLC and associate the client to this WLAN. There are several documents that explain how to configure a wireless client with a new profile.Once the wireless client is associated, go to the VPN Client and click on the connection that you have configured. Then click Connect from the VPN Client main window.
You can see the Phase 1 and Phase 2 security parameters negotiated between the client and the server.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807e0b6a.shtml#tshoot
